1 - 20 of 20 Posts
Air Suspension Manager
This is how she will look like after the air suspension:
Nice wheels :tu:
Is it going to be quickly adjustable?
Not like those but it is going to be adjustable fast enough.
A video from my previous car:
Got to ask - where are you going to "hide" the compressor air tank? I'm in for more pics of your whole setup.
They are all going to fit in the spare wheel space.
Followinf fits there:
* 2 x 200 PSI Heavy Duty AirMadZ Compressors
* 4 Corner AirMadZ Valf Unit
* AirMadZ Dijital 4 Corner control system ECU with pressure sensors
* 10 Liter Air Tank - Custom Made for SLK :))
* All the other parts like relay, etc...
I'll post a picture when it is done.
Fanatical Member
How much weight does this modification add to the car? With all due respect, it's a little too "low rider" for me. It would fit in perfectly in Tijuana, Mexico, or maybe even Southern California! :tu:
Registered 2006 SLK280
Pics..Pics
Don't worry about the height. Maximum height will be at least as high as your car. :)
It is not heavier than what we remove from the car. (Spare tire, 4 springs)
i am curious to know how it will handle as compared to performance after market kits eg Eibach or the KW3 like i have installed .. it is great to look mean and low but can it go around a corner better than the STD set up ..
must admit looks wild
what rim diameter and tyre sizes please.. great work
Discussion Starter #16
Air Ride setups are not as stiff as coilovers. Therefore Kw3's will be better.
Due to nature of air, Air Springs behave like progressive springs.
It is quite, comfortable and hadles like lowered around 4-5cm.
I have been driving air suspension installed cars for 4 years now.
We have been building these cars for more than three years as well.
Air Suspension should provide these:
1. Should sit lower than any static setup when parked.
2. When fully inflated car should be able to enter\exit any garage\shopping mall etc.
3. When inflated half way car should handle at least as stock.
4. When inflated half way ride should be as comfortable as stock.
Due to nature af air when you inflate around %75, air springs stiffens and car handles as 4-5cm lowered :)
Discussion Starter #17
Forgot to add sizes.
Front:
Rims: 19x8,5" ET35
Tires: 225x35x19
Rear:
Rims: 19x9,5" ET35
Tires: 245x30x19 or 255x30x19
ok thanks for all the info ... i guess if you like leaving your car next to the ground when you park it is fine ,, i have enough trouble getting out of mine as low as it is hehehehe
enjoy and look forward to the completed project and whether your tyres rub
Discussion Starter #19
Thanks.
I'll share detailed pictures and videos.
1 - 20 of 20 Posts
