2004 SLK55 AMG
Hello friends,
I share my solution to check, test and coding offline electronics units for (R171 only) with this hardware.
After spent more time to unmount/mount electronics parts in my car, i find a solution to best operate.
https://components101.com/asset/sites/default/files/component_pin/OBD2-Connector-Pinout.png
A module called "Central Gateway" interfacing data signals to communicate with PC and all others electronics unit by CANBUS systems, 3 differents:
Canbus D for Engine motor
Canbus B
Canbus C
Software to communicate with is Xentry or Das and interface is Compact3/4 or passtrought: no need last version but R171 off production in 2011 year.
I was search a picture to explain each bus type connectivity
In first time i using a old central gateway coded with my setup car option and after i connect electronics units to test.
599289
2005 SLK55 AMG /2005 SLK350
Thanks for sharing this. So this is a method to manipulate other control units (besides the CGW) when they are not attached to a car? What are your most commonly used PC software programs?
2004 SLK55 AMG
Discussion Starter · #4 ·
Example of day: playing with Comand ntg2.5 ....
Interface passthrough Tactrix and XentryPT
Next step install all in box (CGW+ODB2 connector)
599314
