Whenever I go over anything uphill, im not sure exactly what I need to replace, its had it since ive bought the car but seeing I havent had time to drive it all that much ive left it. I have new wheels with rims and rotors on thier way what should I replace to eliminate the creak noise?
Premium Member 2013 SLK250
Suggest you lube all the rubber seals around door, top, and boot. Gummi-Pflege is great for this. You might be surprised at what it can do by lubing the rubber seals.
Its definetly the suspension, its at 1998 SLK 230.
Im going to buy a set of OEM front and rear shock absorb and a new set of springs. Is there anything else I should do before I install them?
