hi guys i have a supercharger problem on my '98 R170 SLK230. The supercharger clutch doesn't engage at times and at other times its working perfectly fine. I've realised it seems to this more in the heat and it starts to work again when cool.
I have codes P1235 recirculated airflap signal output stage, P1236 compressor output stage magnetic coupling and P1525. Mechanic reckons supercharger needs to be changed and i just happen to have one lying around.
Would anyone have any ideas or suggestions? Is it worth changing the supercharger over? Any help would be greatly appreciated thank you in advance. :)
Moderator/Founding Member
