1 - 8 of 8 Posts
*******I got it*********No need to reply, Thank you...
I need to locate the hot and ground wires, I have the add a fuse, but no instructions anywhere on where to put it, etc. I decided to just tap into the hot and ground, but they are all neatly wrapped in black mesh and zip tied.....ANy help would be awesome
Don - Founding Member #4
:confused:As I remember, you'll have to separate the wire bundle, find the fat red wire, tap it, and ground the black wire to the body of the car.
I got it, thanks for the replies, just went to the wire loom in the floor instead of behind the hood release like the instructions said. Thanks again
Great! Enjoy it and don't forget to program the 35 mph option.
Just for completeness:
1. Add-a-circuit is connected to one of existing fuse holder in the fuse box located at the left side of the dashboard. This is for the +12v. Red wire may need to be extended. Caution: do not insert any of the fuses until all connections are done. The +12V is constant even with key not in the ignition.
2. Ground wire from module is connected to factory ground near the engine hood/bonnet release lever.
Thread Hijacker
Glad you figured it out, becaues I did the add-a-circuit, and not the fuse holder. Is that what you did (because you lost me)?
Regardless, it's great, isn't it?
1 - 8 of 8 Posts
