Sticking ignition key problems
2359 Views 5 Replies 4 Participants Last post by  i860
Anyone had any problems with a key sticking in the ignition? I've got a 2005 350, battery went completely flat after a real cold spell and the car got quite damp inside. The ignition key now turns to the start position but doesn't spring back, you have to manually turn it back. The starter motor doesn't stay engaged. Anyone got any ideas?? Thanks.
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
See less See more
Yes....get a new battery or the old one tested for starting voltage
Thanks Jeff, I'll give that a try. The usual bad weather we have here in the UK killed the battery. Tried WD40 as a first fix but didn't work ?
Sounds like a faulty eis module, quite expensive those ones. Me i would not put any wd40 in there is to much electronic you can damage(if not damage already ). I will tray a contact cleaner.
