1 - 2 of 2 Posts
Hi
I have a 1997 230 slk with 32000 miles from new. I have put the car up on axle stands and i have been checking for any movement in the ball joints and the steering linkage and found none. BUT when the steering is put on full lock there seems to be some movement in the steering box drop arm area (not the ball joint ) the engine was not running.
When i straighten up the steering this goes away is this normal ?
Also i have dropped the sump guard and have noticed a plastic pad bolted to it what is this for ?
Tim
Tim,
Thank you,
Moderator/Founding Member
1 - 2 of 2 Posts
