1 - 9 of 9 Posts
Premium member 2018 SLC43
I wanted a steam cleaner for a long time, but they always seemed tp be about $750. Discovered some home/consumer grade cleaners recently. Settled on the Dupray Neat at about $194 OTD. Needed for household cleaning, but planning on using it on my cars. Videos and articles sounded good. BUT, this article advises against using one on leather seats. Any guidance on this?
Lots of attachments. I tried the Neat around the house. Easy to use, just be careful. Worked some places but not others. From Dupray's videos, looks like it will work well on nasty carpets. Things don't get as wet as you'd think. Any general warnings or tips on SLK/SLC interiors? Anything melt? Steam temp is 275º F. How are these on wheels? Thanks!
Attempting to steam clean on your own can mean irreparably damaged leather. If the temperature isn't just right, if the steamer is too close to the surface, or if its held on one area for too long, your leather can become stretched and rippled.
Do you have heated seats? Wouldn't want the elements getting wet.
A pita job, I agree, but judging by past members posts it is best to stick to slow and steady cleaning
Slow and steady mistakes are likely to be minor.
Steaming....maybe not so much.
Try a glycerine based leather soap/saddle soap. There's only two seats and door cards along with a few other small areas after all.
Just follow the instructions and you should be fine.
I use a soap made by Stubben.
That should be more than sufficient (y) unless you have another driver in the house
Reactions: DavidD
I've been using Lexol cleaner and conditioner (separate products). Guess I'll stick with those for leather. May be good under the hood, though. I have a pressure washer but people here don't recommend that for engines. This produces very little loose water, though. Thanks all!
1 - 9 of 9 Posts
