It sounds like the problem is in the ignition switch. Do a search there was a recent thread on it.
Have you tried connecting an OBD reader and checking the fault codes, the problem has some of the characteristics of the crankshaft sensor starting to fail.I have a very frustrating problem that I need help with. My 2006 280, 6speed starting having a starting problem about 6 months ago. It would either do nothing or crank and then nothing. It always started after a couple of tries. Sometimes it starts perfectly on the first try. This is not every time but on occasion. When it does start, it does so as usual with no slowness or anything unusual.
I started trying to fix the problem starting from cheapest to most expensive. This is what I've done so far:
1. Replaced the clutch safety switch
2. New battery
3. New starter
4. New alternator
The problem still persists. Now I also get a battery/alternator message on occasion. Also, I will get a ESP or ABS not available after start, on occasion. I'm pulling what little hair I have out trying to figure out what is going on. Can anyone point me in right direction to check?
Thanks.
As well as checking for a bad earth, check the positive terminal, and the "main" fusebox which holds the fuses for the radiator fan, roof pump and a 200 amp fuse for everything else, check the 200 amp fuse, make sure it can't move about.I have a very frustrating problem that I need help with. My 2006 280, 6speed starting having a starting problem about 6 months ago. It would either do nothing or crank and then nothing. It always started after a couple of tries. Sometimes it starts perfectly on the first try. This is not every time but on occasion. When it does start, it does so as usual with no slowness or anything unusual.
2. New battery
3. New starter
4. New alternator
Thanks.
The generic code reader will only read engine fault codes (some may read a couple of others, but not much). To get a full read of all the fault codes an SLK can have from all the various control modules, the car will need to be connected up to the MB Star Diagnostic System (DAS). If, for example, the electronic ignition switch was failing you would see a fault codes showing issues with that component. As you have already found out, you can throw a lot of parts (and money) at the car and not fix the problem. A good session with DAS will likely put you on the right path of finding the real issue.I'll go through all suggestions. The battery was checked and found to be functioning properly. I do have a crank position sensor sitting here waiting to be installed. I figured it's worth a shot.
There are no codes relating to this problem. My code reader shows only one code for a bad tumbler flap. I have the repair kit here and will do that and the cps at the same time.
I think you're right. I will make an appointment to have it checked and see what shows up.The generic code reader will only read engine fault codes (some may read a couple of others, but not much). To get a full read of all the fault codes an SLK can have from all the various control modules, the car will need to be connected up to the MB Star Diagnostic System (DAS). If, for example, the electronic ignition switch was failing you would see a fault codes showing issues with that component. As you have already found out, you can throw a lot of parts (and money) at the car and not fix the problem. A good session with DAS will likely put you on the right path of finding the real issue.
Any follow up on the story?I think you're right. I will make an appointment to have it checked and see what shows up.
In another thread he says dealer replaced EIS module and starting prob solved.
Ed
