1 - 18 of 18 Posts
Thanx to a member I was able to find a seat belt buckle replacement for $80 instead of the $350 I was quoted at the shop without labor, yippee! I was about to order it but then it gives a left & right parts :( At 1st I thought I would need the left since its the drivers side but its placement is actually on the right side of the seat...Now confused so which part is really for the driver side.....left or right?????? HELP!
is there a part number on the part?
what is it?
then we can tell you
or if i know your vin number
(Have you requested your free datacard?), we can get the part number
The part numbers are for either left side of CAR or right side of car.
Usually comes in one set and labelled right or left, not driver's or passenger side
This is what is confusing to me... left = drivers side or right = side of seat?
Jeff I think you gave me my datacard in tween Sept - Nov
I was about to order 170-860-09-69 left position???
mb rarely goes by driver's/passenger due to UK cars RHD and USA cars LHD
so they will post a pic in epc and the part description
standby
pm me or post your vin
09 69 is driver's side left
but post your vin to be sure
you can see from the attached pdf
that the left and right are listed but all are called driver's seat
Standby...
is that your vin?
that is a r171 vin not a r170 vin
don't you have a 320? that is for a 350 r171
hmm let me check again lol
03 320
hmmmmmmmmm that is the only data card on my PC :(
getting it from car lol
WDBKK65F03F272731
03 320
WDBKK65F03F272731
what this above is different from the one you posted in the other post
standby
Here is yours
same part number
remember that your vin tells epc it is a usa car
left in usa is always driver's side
look at your datacard again
does it say r171 or r170?
if r171 you have the wrong datacard and i will post your correct one
here is your datacard
Discussion Starter #18
SRS Light issue Update
I had the driver seat belt housing replaced & had codes reset! There are absolutely no faults now but the darn SRS light is still on so I put the electrical tape back over it. Guess I have to wait until that bulb blows out since it on constantly. Just hoping when it does burn out it wont cause another warning light to come on lol
1 - 18 of 18 Posts
