I read in various posts that you must use MB coil compressors on an R170, and hell will freeze over if you use the cheap external type, but why is that? Had a peek under the car today and they just look normal, what the issue with external compressors?
Discussion Starter · #4 ·
It took a full day, but I concur with what has been written, without those coil springs and a ramp, fitting the Eibachs is not easy, for a novice anyway, even after compressing, there is still a way to go to prise them out, even after releasing the shock and other bits, but got their in the end, now rolling 30mm closer to terra firma.
And they only cost £115, parts for this car are unbelievably cheap. Bought an equivalent set for an E30 and it was £259.
Thanks for your help.
