I've just fitted it , took about half an hour , rad cowl off and access the tensioner pulley , cleaned off the existing bottom pulley and bolted on the oversize one over the top and installed the new supplied belt .
There's a definite improvement in low down torque and better mid range pull but it does run out of puff towards the red line , more so compared to standard . Hopefully a remap should help this , as should a bigger inter cooler and an extra inlet into the factory air box .
If I've got time I'll also see if I can get larger down pipe and maybe dump the cats and make up a better exhaust system , although I don't want any more noise so this may prove difficult !
