I understand that the speed that shows up on the speedometer is registered from the number of times the wheels spin.
Does anyone know which axle the computer is analyzing?
aka John
On the R171, it's looking at all four wheels, but I don't have any idea what formula it's using to calculate a final value.
the esp module looks at all the wheelspeeds and determines the true speed, then sends it over can to the cluster/m.e. and whatever else wants to know. This is how some of the benz's can determine if a tire has low pressure it notices when the car is going straight one of the tires has a significantly higher rpm due to smaller diameter of a tire low on air. This is before they were using tpc. it also uses that same logic and looks at your steering angle sensor and if it sees a certain steering angle say 10 degrees off and notices all the wheels have identical speeds it will throw a esp code- so you have to get an alignment done.
