1 - 14 of 14 Posts
· *Registered
2006 SLK350
I'm looking at upgrading the door speakers as they're the same ones that came with car nearly 20 years ago. I don't think they're HK speakers.
I understand that the standard speakers are quite low profile, are there any aftermarket speakers that fit in the standard pods?
· Founding Member 2006
· *Registered
2014 SLK350
Not sure about the no HK system as my R171 had the HK however I was able to replace with a low profile infinity speaker but it took a lot of modification to the bracket to work
· *Registered
2008 SLK350
Hi TheMunchBunch,
I did replace my speakers in my R171. I did not have Harmon Kardon. There was a great step by step guide which I followed with recommendations of speakers which I have followed. Just search in advanced search for "Full Speaker Upgrade" from nitro28. You"ll find it.
The only difference is that he had Harmon Kardon installed originally and I did not. My larger speaker touches the grill and pushes it a bit out, but it almost can't be seen. The door cover must be different at the normal sound system.
However, look for this post it helped me tremendously.
All the best with your upgrade.
· *Registered
2006 SLK350
Discussion Starter · #6 ·
Hi TheMunchBunch,
Cheers for that, I'll have a look into it!
here tis:
· *Registered
2015 SLK250 CDI
Why are you looking to replace them? What don't you like? I've got an R172 and the sound is pretty good, once optimised.
Many people don't know what to listen for. I do. Ex national Sound Quality judge (2015ish), I've run a national manufacturer competition team and helped setup cars that have done well internationally (2nd/3rd in Europe)
The speakers aren't amazing, but they're better than most people's. The standard setup in no way optimises them, though. 15 million speakers just makes things worse. I was considering a full replacement, then found out how to enable the fader. Forget the rear speakers.. fade full front, 2-3 steps towards the passenger, and +2-3db treble and +4-5db bass. More speakers isn't the key to success.
Sure, it's possible to do better, but in the stock locations? Even with sound deadening, better speakers and therefore better amps, plus time alignment? The improvements would be minimal
If you swap, you're likely going to add less efficient speakers, which means more amp power.. it's a trouble-fraught route
I've listened to 100s of cars, setup many and i won't be replacing mine unless they're blown.
If you do want improvements and they're not blown? Best improvement will be to add a DSP with time alignment first
· *Registered
2006 SLK350
Discussion Starter · #11 ·
Thank you for that, I'll have a play about with the settings and see if I can dial them in a bit better. The sound quality in the stock speakers aren't fantastic but I'll give that a try again and see if I can work some magic.
If not then the goal is to replace the headunit, amp, speaker and subwoofers.
· *Premium Member
2005 SLK350
I changed the speakers in my 2005 SLK350 for new speakers from my local MB dealer that were significantly cheaper than you find them at breakers in the UK! I also replaced the head unit with a pioneer job, for Apple CarPlay, and it made a significant difference. Am I cruising down the beachfront with my toonz to the max? No, but it did make everything audible and significantly better than it was before.
· *Registered
2015 SLK250 CDI
The stock setup is a mess, for anyone into true stereo audio. I had people jumping from behind my right ear to the left of the dash in front of me (rarely do people move around in a stereo recording). Get the best from what you've got before upgrading :) Spending money is the easy way out, and sure, it'll likely sound somewhat better with more expensive kit, but I'd put a well tweaked stock setup against a poorly tweaked aftermarket one any day.. and 99% of people don't know anything about setting up a system beyond increasing the bass levels and blowing their speakers
1 - 14 of 14 Posts
