Hello All
I have read many posts on here about speakers without much luck
My seat is nearly all the way back as im 6foot tall.
the stock speakers on my car are ok but not the best for sound and i find it a little odd hearing sound from infront of me only.
What do you all recommend, i am thinking that maybe to get some three way speakers and put them in the holes that should be behind me to give some more sound or maybe
replace the fronts with better speakers and add speakers in the rear
the sound in my car is rubbish when the roof is open and when its closed i cannot crank it up.
Help Please!!!
when you shop for speakers it will be harder because you have to remember that the car is a convertible... a speaker that will work good in a normal 2seater won't be the same because of that.
do you have a local shop that does professional sound work? if you don't I have one here.. and I can give them a shout on recommendations they have.
that would be excellent if you could as the local one to me is 50 miles away and not very informative when it comes to the SLK.
most audio install shops died with the ressesion over here...
