Looking at your photos, the first and third just show stone chipping, with the white undercoat showing through. This is very similar to what I have seen with red Alfa Romeo sports cars. The second picture shows the clearcoat coming away is and is possibly the problem except that if this is a plastic panel, the well-known paint problem is said to only occur on the metal panels.
My SLK is a late 2015 and appeared perfect when I examined it at the dealers in October 2020, only for what looked like microblistering to appear in late November. At the time I thought I'd get it sorted in the spring of 2021, only for it to disappear from view in the spring !! I did a small repair on the rear wing top behind the driver door where the clear coat was peeling slightly. I flatted off the clear coat all around and used an aerosol can of clearcoat to recover the area, then polished. This has held up so far. As far as I can ascertain, the fault lies in the clearcoat, not the base coat.
If you're not a rich man, then it is possible to respray small areas using aerosol cans, the trick is to use quite fine flatting paper and not go at it like a bull at a gate. My final flat paper was 1500 grade. The lower front valance needs totally flatting down and refinishing to get rid of the chipping. Not difficult, but you need warm weather. Then try to cover with some of that clear vinyl film one can buy.
When I had an aluminium XJ6 I had to do quite a lot of paint repairs where the dreaded aluminium corrosion had occurred.
