Hi, after overwintering in the garage ( the car - not a wife instruction! ), it's now time for cruising the roads of Denmark..... But my brakes seems to have lost its grip - first time i hit them - second time it's much better....
Is that just a simple problem of air-bubbles in the fluid, caused by a looong vacation without driving??
Registered 2005 SLK350-sold
Possibly just surface rust on the rotors, and normal use cleared it off. If they feel good after a drive and cool down, that is probably all it is, if they still feel soft/weak probably something else.
**Registered 2009 SLK200
If they need a second pump etc to firm up check for any signs of leakage !
And after you have driven car as pre mentioned they still feel spongy .
Check vacuum hoses there are no leaks etc .
Bleed brakes all round using special bleed pump !
Its prob slight air bubbles in the system causing it .
2004 SLK200
Check for fluid on garage floor. Break system can't develop air bubbles without a leak. You can have fluid boiling temperature degradation after a long vacations, but during normal driving that makes no difference.
