1 - 20 of 45 Posts
Registered 2007 SLK55 AMG
I’m slowly accumulating tools for my SLK55 and am not having luck in searching out the correct size socket required to remove my Wheel lug nuts. Which socket should I purchase?
:D
until a reply
you checked the lug nut wrench in your trunk? size might be written on it or you can compare the size
I decided to clean up under the spare tire, and saw the lug wrench. When I tested it, It’s was too small for my wheel lugs, but is perfect for the small lugs supplied with the spare tire. Am I possibly missing a lug wrench for the factory toolkit?
If you are going to work (mechanically) on your car, surely you have a metric (in all likelihood) socket set that you can "test fit" sockets to those lugs?
see my message ref: datacard
then when we/you post your vin
we can get what should be in your toolkit
look here
as mentioned
post your vin
get free datacard
get wheel info - might include lug nut size
you might have bolts and not nuts....my 2009 55 has bolts
that might be why
here is my 55
A 000 990 48 07
SPHERICAL COLLAR BOLTFRONT AND REAR; M12X1.5X40
Replaces: A0009901007
Quantity: 20
A 203 580 00 10
PARTS BOXSTEEL DISK WHEEL; M12X1.5X21
Code: 669;
len is right 17 mm at least for my 09 55
POST YOUR VIN and we can check
A 221 581 00 01
SOCKET WRENCHWHEEL MOUNTING; SW17
Replaces: A1205810246
A 120 581 02 46
COMBINATION WRENCHWHEEL MOUNTING; SW 17 MM
It requires a thin-walled socket to access it.
Here is datacard
and
tools
and wheels
1 - 20 of 45 Posts
