Car starts and runs for a few seconds but will not restart or even crank after the first successful start, most of the time. unless i disconnect the battery which will result in the same "start-run for a few seconds-die" cycle. No OBDII codes. Checked/re-soldered k40 relay module. Still no start. I have red and green alternating lights on module by rear-view. What should my next step in diagnosis be? Or is it pretty much for sure my DAS?
2001 slk320 sport non-komp. v6.
Founding Member 2006
How old is battery?
Has it been tested for cranking voltage?
please post an intro thread
members will chime in.
Registered 2002 SLK320
Hi !
I had a similar problem with my beloved 320.
After a week at the dealership and they said couldn't troubleshoot properly, the Indy shop I trust replaced the PSE pump that the components inside were fully encased in rust and lime scale.
They also traced a short on the wiring loom around the edges of the engine bay that caused rogue problems.
Haven't had an issue in years since.
Hope this helps.
A
