1 - 13 of 13 Posts
Hi I have a double exhaust with a single oval tip but I want to change it for a double tip the same as the slk32 amg has any one know where I can get one ?
Ask around in your area for exhaust manufacturers, maybe you can get a similar design like the slk32 amg or some other style you would like. Or look for brand new/used slk 32 in the web, mercedes stores or the scrapyards in your area.
Also when I was in the uk, guys in the shop "carnoisseur" was helpful, maybe you can ask them to source this part for you.
Per ardua ad cineris.
Only if you put on the decal from the exhaust tip company. The slick surface of the decal reduces wind resistance.
I was lucky, and got three stickers with my exhaust.
I can't even begin to work out how much power that liberated, but it must be almost 1000 (10^3).
Where can I get more of these stickers?
Does a clear-bra have the same effect?
:dunno:
Ahem.
Sorry about that.
You asked for tips;
First one is don't ask a question when people are in a flippant mood!
Second is that the SLK32 is a V6, so will have a different exhaust; I realise you only want the tips to match.
There are many routes top this; depends on the alignment of your existing tip in the slot.
Mine has the existing tip to one side, so I would have to re-make the back-box assembly to get a different tip.
You may be lucky, and have your existing tip in the centre, in which case you can bolt on an after-market goodie. Or take off your pipe, and get a proper one welded on. Probably come to about 50 GBP.
The final one is to get a replacement back-box assembly; Powerflow would be 200 GBP for that, but I've heard stock is much cheaper (!)
Discussion Starter #13
Any luck deciding how you are going to progress?
And suppliers?
Hi not as yet but have got the slk 32 amg spoiler for the boot sorted at a great price of £24 inc p&p from Taiwan sprayed the same color as my car and it came in about 5 day and looks great :bannana:
1 - 13 of 13 Posts
