Go to a different dealer and see what they find.
I agree about getting a second opinion. Also, do a search on this site for weak battery as several of your symptoms are those of a weak battery. These cars need a near perfect battery and just because the battery is able to start the engine is not an accurate test of the quality of the battery. Have a conductive test done on the battery before you do anything else. If the battery has any weakness replace it then see what issues you have.Hi
I hope I can get some help here.
I got the ESP wasrning light come on, turned the car off and on and it went away. car running perfect. after a while checkengine light came on, took it to autozone and they told me that its the oxygene sensor I replaced the upstream o2 sensors, reset and checkengine light came back on after 20 miles. took it to a certified Mercedes mechanic and his diagnose was a bad ecu. the car is running fine. very rarely it will stall ( it happened once). I am out of the 8/8 . I don't know what else this can be, I am having a hard time believing that it is a bad ecu since its rare that these will go bad please help
Not sure if Autozone would have the tester. It is a fairly quick and easy test to do if the shop has the proper equipment. Many places only test for the current voltage or some type of load test. The conductive test determines if each of the plates in the battery can flow the full current at the rating of the battery. One weak plate and you can have issues with the battery.Hi I am planning to go for another opinion, but I am wondering what do you mean by conductive test? is that a normal battery test that autozone can do ? I believe the battery is fairly new, I am going to check what year it is but I think its about 1 year old
what equipment do I need to run that test. and where can I find instruction of how to do it ?Not sure if Autozone would have the tester. It is a fairly quick and easy test to do if the shop has the proper equipment. Many places only test for the current voltage or some type of load test. The conductive test determines if each of the plates in the battery can flow the full current at the rating of the battery. One weak plate and you can have issues with the battery.
If you do a search on this site you will find many stories of SLKs having all kinds of electrical gremlins from dash warning lights coming on, to false check engine light trouble codes, to the dash cluster and other components not working at all, and so on. In most all instances the car would start and seem to run without issue other than the gremlins.
So, when there are a couple of seemingly unrelated gremlins popping up, the first thing to check is the battery and the test must be good enough that a false positive won't be given (like just checking battery voltage).
For the record, I test every battery before I purchase it. More than once I have found a new battery that fails the conductive test. And, I have never bought one that passes the test that I have any issues with for many, many years. I maintain about a dozen cars plus several pieces of farm and construction equipment. I have tested a lot of batteries.
Good luck and let us know what you find.
Maybe this may help you understand the scientific basis: Why do Different Test Methods Provide Dissimilar Readings? ? Battery Universitywhat equipment do I need to run that test. and where can I find instruction of how to do it ?
That's puzzling. Did the MB dealer replace the O2 sensors that were only two days old?
When you replaced the two O2 sensors where did you source them and what make are they? I have had situations where generic O2 sensors were used and they caused issues.What are the chances for 4 o2 sensors to go bad . The codes that the car is throwing are still saying the same bank 1 sensor 1 bank 2 sensor 1
