1 - 9 of 9 Posts
Dear All Slk Bro,
I need some help on yours, as today i try to close the driver side window after i drove my SLK once a week, and the window did not goes up, ( this problem happened last time when i drove my car in last week), and i search the forum for fixing this problem as i turn the key to level one and push all the window down and hold for 10 sec, but today this happened again, would you please help to tell me that will it be any other solution?
Appreciate a lot.:tazz:
did you try instead of pushing the windows down, you set the window travel by pushing the windows UP for those 5 seconds?
When I travel, normally I pulling all the window down. But when I get back to my car park, the driver,s window did not goes up. What happen?:soap:
so how do you normally get them up when this happens?
normally to set the window travel after let's say replacing the car battery, you would
Synchronizing power windows
The windows must be synchronized after the
battery has been disconnected or if the windows
cannot be fully closed (Express operation).
Each power window must be synchronized
separately.
Close all doors.
Switch on the ignition.
Pull and hold switch 1 or 2 (Y page 89)
until the respective window is closed.
The window opens again slightly.
Pull and hold the respective switch once
more immediately until the window is completely
closed.
Hold the respective switch for approximately
1 second.
The window is synchronized
separately.
Close all doors.
closed.
1 second.
thanks a lot buddy, i will try this today. Keep in touch, appreciate that.
Simple. I took care of it for you.
1 - 9 of 9 Posts
