Hello,
I really need help im having some weird intermitant shaking when I turn my car on..
Sometimes the misfires occure only in D or R gear sometimes in every single one even in neutral.
I changed all my spark plugs.
I went to the mercedes shop and they told me I had a "cyl. #3 misfire", but everything is ok we testee it. The compression is pretty good as well, fuel injectors perfect..........
And sometimes there is NO misfires and the car runs "good" (like yesterday)
I have no idea really need help please.
slk 230, 2000 with about 104.000 miles.
I recorded the misfires in P gear: https://m.youtube.com/watch?v=ZaMPLtOMdMw
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
Premium Member 1998 SLK230
I had a similar problem,
a few months after I had the dealership replace the coils & spark plugs
the check engine light came on & the engine ran rough.
I restarted the car, the misfire was gone & the engine ran smooth.
I took the car in to the dealer & they read the codes saying there was a misfire on 1 of the cylinders.
They did some tests & swapped the coils around & still could not get the problem to repeat.
There was no charge as the parts they were checking were under warranty.
A week later, same problem I drove into the dealership with the car misfiring & asked them to leave the car running till a tech was able to see the car. It was a faulty coil & they replaced it for free.
I would have your mechanic swap the coils, next time you get a misfire take it in have the codes read & if the misfire moves to another cylinder its the coil.
That was my understanding of how to best diagnose this. If your plugs are good, swap out your wires. See if the fault follows. If it does, replace the wires. If it doesn't, swap the coils. If the fault follows the coil, you have found the issue.
Worked for me. Sadly, I've had to replace both coils over the last 6 months. On the plus side, I look at it like there is less to go wrong now!!
Cheers,
Jay
