1 - 8 of 8 Posts
Availability and price of a pair of SLK 230K Headlight Washer Jets for a 2000 Reg.UK vehicle. I have searched various sites.Plenty of washers.None that look like the ones fitted to my SLK.:frown: Have they
been replaced by an updated type ?
Super Moderator
Welcome to SLKWorld.com: The #1 Mercedes-Benz SLK Forum!
First please update your location & vehicle (model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Info in your garage does not update your profile.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members-introduce-yourself-here/330737-how-update-your-profile-post-intro-smartphone.html
Super Moderator
@Turdo2
@Livefreeordie
@efair
@savcom @Simon cliffe @devilman9050 @stu32
R170 experts are on their way.
Not forgetting:
What's wrong with your units? Not many headlamp washers were fitted, if I'm honest, but if they are then depending on what's wrong, like as not someone here would have found a fix. I stripped and cleaned mine which worked wonders (no further trouble) so give us some more info about your problem and we can try and help!
Morning all, thanks for reply. the problem is blocked jets.Water pressure from the pump,blows the jets off the plastic pipes.
The jets fitted look like sealed units.Are they repairable,and how do you take them apart ??
I don't think they are repairable. If they are blocked can you not try and force water the wrong way with a tube on the top and hose pipe. Perhaps leave them soaking in some Milton overnight may help first and/or some thin wire to poke them clear. Dronsfield in Oldham break a lot of Mercedes and may have some good used items on the shelf.
I hate headlight washers - they are such a PITA - and waste loads of water/screenwash.. last 3 cars i have had i took the relay out so they didn't work..
1 - 8 of 8 Posts
