1 - 9 of 9 Posts
Hello guys,
does anyone know how to proper adjust the (closing)limit of the windows,
have tried it once but now they are back in the old position wich is a little bit to high.
are there any drawings available of the window mechanism?
that would be nice :tu:
I had a similar problem with my 2000 SLK230. Aparently there is a metal part that should be bonded to the glass that comes loose - or it had in my case. Got the merc dealer to fix it - took two atempts 1st attempt failed - 2nd is OK (no charge).
Hi.
I have the same problem in mine. I took it to Mercedes Service and they told me I need a new glass which costs £200. I want to buy one of eBay but need to make sure that it has got that metal bit. Does anyone have picture of what to look for please?
Cheers!
eterem,
Thank you,
Founding Member #12/Moderator
Registered 2000 SLK200K
there is a pin glued to your window's lower end that limits the upper movement. You should see it in the speaker hole when the window is down. the window will move up above the limit if the pin is missing. you will probably find the missing pin inside the door. check it from the other door if it works fine...you need some strong glue to fix it. it is a medium level DIY if you are experienced.
1 - 9 of 9 Posts
