I have a 2001 SLK 320 and am looking for how to attach these aftermarket running lights but finding nothing.
Here is the link to the set I purchased:
Euro 8 LED Daytime Running Light DRL Kit Fog Lamp Day Driving Daylight M.Benz | eBay
I need to know how to get power to them. I understand many people say hook it up to the battery and ignition switch but I cannot find the ignition switch and I am not sure how to hook something up to the battery with the negative arm in the way on the terminal port of the battery.
It would also be helpful if you knew how to mount it!
Thanks!!:biglaugh:
Registered 2003 SLK230K
hello
it is late, but i will look tomorrow and tell you the fuse to tip into in th efuse box under the hook. pretty easy but you should use a relay.
baller722,
Thank you,
Moderator/Founding Member
