Hi
I have recently purchased a 1999 SLK 230k with 59k miles on the clock.
The car initially appeard to run fine, it then developed a misfire on cylnder 4. When the car was switched off and re-started it went away, then when the engine was put under load the fault returned. There was a significant lack of acceleration and the engine sunded like it was going to stall when at idle.
I have changed the coil packs and the spark plugs. The car can run fine for 100 miles and then the fault can re-occure. It seems to be once the car has warned up and then been allowed to stand for a few momens. It will then sometimes start to judder (missfire). I have also changed the oil (and filter), air filter, fuel and polen filters (all parts came from Mercedes).
The frustration I have is that its intermitant and despite hours of reading various forums its quite difficult for me to diagnose the underlying problem. My next port of call was going to be to clean the MAF and possibly replace the injector in clyinder 4.
I believe because of the low milage that car has probably spent most of its life stiing around in various garages.
Has anyone had any similar problems? I am not a mechanic but am willing to get my hands dirty and have a go.
Any help would be really appreciated, The SLK is a great little car!!
I will update my profile shortly, I am located in Kent UK. :tu:
If you haven't, please update your location/vehicle (model and year) in your profile as it helps the members answer your questions which usually are based on that information.
Thank you,
Moderator/Founding Member
Oh and moving to r170 general discussion section
Premium Member 2002 SLK230K
Welcome. I had a problem under a load and always ended up in limp mode. It turned out to be a cps ( crank position sensor) it's a cheap and simple job.
Hi, Thank you for this, I will change the CPS and see how I get on.
I should have mentioned that the initial delaer scan revealed the below codes as 'Not defined'
P0130-015 - G3 (Right O2 sensor, before TWC [KAT})
P0720 - Read out fault memory control unit ETC.
P0204 - Y62y4 (Cylinder 4 injector)
P0300-080 - Misfiring Damages TWC
P0304-083 Misfire of cylinder 4:83.
On the basis the coil pack and plugs have been replaced in cyliner 4, its got me thinking it could be the injector in cyllinder 4 which is weak / dirty. Any thoughts on changing that, it looks to be well inside the engine?
Appreciate any help
Best
Daniel
Appreciate any help
Best
Daniel
If the 02 sensor is bad, it will cause misfired. Since the one of the code is an 02 sensor then it make sense the misfired. So your next step would be replace the 02 sensor before the CAT. Make sure ONLY buy the OEM sensor.
Appreciate any help
Best
Daniel
That kind of changes things,. Like mentioned above o2 may be on it's way out.
