front bottom arms bushes have worn out . is it a easy job to remove the bushes or is it better to replace the whole arms. any tips i do have a hydraulic press to use . but they been on the since new 2005 .
Just replace the whole arm, they are not very expensive. $86 for the OEM Lemforder from FCPEuro. I would expect you can find something similar across the pond.
if i change one i will probably need to change all 4 . i found i can get them both bushes and arms .
im going to remove one today if i get time and see if the bush comes out ok if not i will swap the whole arm over .
I have seen 2 types of bushes - one that would allow the use of camber bolt to increase / decrease camber, and the other one can't (i.e. just have a simple hole). Be careful on which one to go for, if you are indeed using special camber bolts and installed them the way accordingly for that purpose
