1 - 9 of 9 Posts
2006 SLK350
My 2006 SLK 350 (r171 FIN WDB1714561F117107/ VIN WDBWK56F76F117107) started to develop a slight clicking noise under load (in drive) but not while in park. I did a transmission service, rear differential fluid change and upon removing the exhaust and heat shield to inspect the centre support bearing on the drive shaft, I noticed that the rubber boot was in poor condition (pic).
I've removed the drive shaft to replace the drive shaft flex discs, the centre support parts and the transmission mount.
My issue is ordering the flex discs as they have different part numbers but every site I go to only shows me one flex disc number (I'm in the belief that these are the original parts). I presume the part numbers have changed over the years but I want to make sure I order the correct ones. The ones I removed are listed:
Front flex disc: GAD 134 210 411 02 15
Rear flex disc: GAD01-020 211 411 01 15
Looking for assistance in ordering the correct flex discs.
Automotive tire Automotive design Automotive exhaust Automotive exterior Automotive lighting
Automotive tire Rim Automotive wheel system Gas Auto part
Automotive tire Rim Font Automotive wheel system Audio equipment
Founding Member 2006
from your vin
items 150 in attached list
let me know if the above helps :D
Computer Rectangle Font Screenshot Operating system
1 - 9 of 9 Posts
