Dave Hybrid Shifter 2.0 is getting closer but no bloomin Cigar yet ....
The biggest issue there now is going to be trimming and fixing the Leather Gear-stick Gaiter around it all so it is nice and neat and "how one would expect it to be in ones Mercedes-Benz don'tcha know" 🤣
The other option is to abandon the W204 Display idea and just use an illuminated Push Button for the Modes mounted here ....
If I could find a wee oblong Momentary Push Button to match the little Airbag Off Light on the right hand side I think I might well take that option, certainly haven't ruled it out yet
Time to take a break from the Shifter now and go get my paint brush out again down the Garage / Paint Booth
Softlee Softlee with this particular Monkey
This Shifter sub project is not yet at the "yee-ha light up that fat boy Ceeegar" stage, but it is getting closer, and I don't wanna screw it up now and then have to cut out yet another ally top plate. This is currently top plate # 3
Methinks the final trimming of the Shifters ally top plate and final mounting height for the Gear Indicator / Mode Switch will not be possible until the Shifter is actually installed in the car, and that's not gonna happen until after I've installed 7G and stuck some miles on it in S mode using the original Shifter, so we all know for sure it's actually gonna work out OK
Another issue has surfaced regarding my Paddle Shifters, the Tiptronic on this later Shifter Module won't work with my Paddles being hard wired as the stock R170 Shifter Module does (Earth Pulse based). That now means to reinstate my Paddles I will have to set up a simple Body CAN Bus and use that for all the Steering Wheel functions on my Paddles and Android
I suppose that's no bad thing for possible future mods to the Car, but yet another sub-project within the grand scheme of the 7G project
All I can say is no one said this was gonna be easy, and there is very good reason that it appears no-one else has documented successfully stuffing a 7G up an R170 / Crossfire yet
TBC ......................................
