Well our boat trip got cancelled due to excessive winds. Nope, we did not have Curry last night, that's tonite
PM me wot to PayPal ya
There are a couple of Wire Colour differences, from R170 to X/Fire but they go to same pins Cluster and Component ends
There are only 2 differences in the Cluster Wiring Pin Outs between R170 and X/Fire
Plug 1 is Identical
Plug 2 is Identical except for ....
Plug 2 Pin 2j R170 is Plug 2 Pin 1i on X/Fire
Plug 2 Pin 2k R170 is Plug 2 Pin 1k on X/Fire ....
1) I'm gonna conclude you got a duff Cluster which caused your errant Needles
2) I'm gonna conclude that XF uses a different Fuel Tank Sensor to MB hence my errant Fuel Level readings , or perhaps that was due to the 2 different Pin Outs mentioned above back-feeding the Fuel Gauge somehow ??????????????????? So I will have to try swapping those pins to see if all is then well with Fuel Gauge
The PCB's have to be different for the different Fuel Low and perhaps other Warning Lamps
Yes um please umI've got 3 of them and I'm assuming that you want one that I've not removed the green from?
Because you like green for some reason
That'll be the top one then![]()
SRT-6 and X/Fire 160 MPH are identical pin outs.My admittedly low-tech experimentation and thus conclusion is the same as yours in that they look the same but the boards are different. I'd suspect said person did a overlay and needle swap only![]()
Plug 1 is Identical
