Hello all,
Since a couple of weeks I own a SLK 320 (2000)
Unfortunately I already have some challenges with the Xenon light.
One of the headlights stops after a few minutes.
I bought two new xenon lights. When I replaced the which stopped after a few minutes the new Xenon light works properly for a few seconds but then starts blinking and stops after a minute or so with shining
When I also replace the other lamp then they both stop shining after a second.
Is somebody familiar with this problem and can you advice what I can do to solve the issue?
I wrote somewhere that is could be the ballast, where is it located in the SLK and is this something which can be adjusted to solve the issue.
In addition, it seems like a good idea to buy an obd. is there anyone who can recommend a good obd scanner for the slk?
And what exactly could I expect if I purchase an obd regarding my car light issue? will it immediately indicate where the problem is, or does it only indicate what the malfunction means in general, such as a problem with the headlight?
Thanks a lot for the support,
Martijn
Martijn
