I was wondering if there was any kits or anything any of you know of to rebuild the engine or what parts I'm going to need?
You have your vehicle in your profile as 2006 350
But your title says 32 rebuild
So what are you planning to do?
Ebay has a lot of the parts individually for a complete M112 rebuild.
things like: rings, crankshaft main bearings, rod bearings, complete engine gasket kit, timing chain and tensioner kit. and most likely an oil and water pump.
but my #1 rule: if it aint broke, dont fix it!
The engine you have is a very individual unit. AMG changed most of the standard 3.2 V6 bits including the block so any parts you source will have to be for a 32 AMG. Bearing in mind that will be difficult and probably expensive then @Turdo2 s No.1 advice is very good.
Premium Member 2004 SLK32 AMG
Welcome from fellow 32 owner. We have a 32 member who burned a piston recently. Do a search....he may have some valuable lessons for you IF it is something that must be done.
