I just recently bought a '02 SLK 32 AMG. I was wondering what modifications are available to increase the horsepower and if there is a recommended shop/mechanic in the Nevada/Southern California area that can do these modifications (correctly)
Kleemann ECU/Pulley kit
Kleemann High Performance Camshafts
SL55 Y-Pipe
Green Filters
Kleemann LSD (One of a Kind in USA for R170)<--Doesn't add horsepower but it is a performance mod
Exhaust was not touched as the cost vs the increase was not feasable as the AMG exhaust is pretty wide open.....also You can not run a true dual as there is not enough room under the car to run pipes coming straight off the main exhaust like there is with the new SLK55.
You can also get headers for the SLK32 but there is very little room to put them in and would be very expensive for the little increase you get from adding them and again....Not worth the money for the little increase
I prefer Kleemann over Renntech but its like Chevy/Ford.
I've had no problems with any of my Kleemann mods.
I dyno'd (In Florida) 360 rwhp and 349.8 rwtq.....Roughly 410-430hp at the motor.
I think that both Renntech and Kleemann should suit you fine......But you have to decide which one to use....Kleemann or Renntech.
Brabus may have some left over parts for the 32. The crossfire crew in So Cal have been pounding them (Newport Beach) the last few weeks for suspension part.
