1 - 8 of 8 Posts
Can anybody tell where can I get a vario pump. Due to pump working but i no movement. We think this has loss pressure.
:tazz:
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
Hi Ramon-
Welcome from a fellow 230 owner in New England.
Did you check to be sure the fluid was full?
I believe that can cause the pump run/ no roof action problem.
Good luck,
Christian
Welcome from Texas!
Lots of troubleshooting to be done before dropping $800 on a pump. I've only been on here for a little over a year and seen all kinds of top problems, including my own. I have yet to see a bad pump.
1 - 8 of 8 Posts
