I have a 2001 SLK 230 Auto. 71K The car bogged down while driving yesterday. I checked the codes and it showed a P0101 and P0221. I had replaced the whole throttle pedal unit two years ago so I find it hard to believe it's the the throttle sensor switch. After shuting it down it started find and drove for about two miles then bogged a little then ran normal. Any suggestions would be appreciated.
Discussion Starter #2
Solved problem
Found an air leak in the hose down line of the MAF. Fixed, then reset the throttle and it's running like a charm.
Fantastic job!
