1 - 20 of 25 Posts
2001 SLK230
Hello everyone , i recently got an slk 230 2001 model with abs bas esp lights that illuminate when i start the car everytime , the battery was weak and i changed to a recently new one , did lock to.lock steering wheel turn but no luck , the owner had already replaces the abs pump in front (ill add pictures) esp code is A1705450132 , i have gotten my.car diagnosed and it shows up the left and right rear abs sensors but i replaced those from an working 1997 slk 200k , and yawrate sensor which i already replaced but didnt erase the codes , the roof wont open , it flashes red , speedo works , car is manual 6 gears . I tried another abs pump from a w208 clk kompressor but didnt seem to work, what do u guys suggest to do . Thanks
Gas Font Auto part Metal Nickel
Motor vehicle Vehicle Automotive tire Automotive exterior Bumper
2001 SLK200K/2001 SLK320
From your profile you have a Post Facelift R170 SLK (MY 2000 - 2004), as far as I know the ABS Sensors are NOT compatible with with a Pre-Facelift R170 SLK (MY 1996-2000) and vice-versa. The same may well apply to the Yaw Rate Sensor.
Use the correct ABS Sensors and you may well find that the roof works as it should.
2001 SLK230
Discussion Starter · #3 ·
Hello my friend , i swapped those abs sensor from this model (2001) to the old model (1997) and they worked back in the old slk , they looked the same and everything, are there any difference between facelift and old models that i should know?
Let me get this right right then, you're now saying that they're not from a '97 but an '01 after all?
2001 SLK230
Discussion Starter · #5 ·
I swapped rear abs sensors from my 01 model to 97 model and vice versa , they worked on 97 model and both sensors looked the same, in my 01 slk i have the 97 slk sensors but still the diagnose says rear sensors , sensors are okay and tested
Wiring from Sensors to Module ?
Reluctor Rings ?
Module itself ?
Reactions: M4rCu5
2001 SLK230
Discussion Starter · #7 ·
Reluctor Rings ?
Module itself ?
I got my car checked and the mechanic said the wiring is okay , rings are clean and no.damage at all, i suspect the abs module which was changed is not the same part number , i got this code one day P202B CAN communication with esp not available or smth
Sounds like wrong Module then that will definitely give issues !!
Reactions: M4rCu5
2001 SLK230
Discussion Starter · #10 ·
Thats what i think but i dont have the original abs module to match the part numbers, can someone help me with a SLK 230 from 2001 to check out the part number for abs and esp
2001 SLK230
I replaced the ABS Module on my 2001 SLK230. I bought the pump and module from a totaled '01 and just used the module. Here's a photo of the pump and module that I purchased.
Automotive tire Headgear Gas Font Auto part
Snow Automotive tire Motor vehicle Asphalt Font
2001 SLK230
Discussion Starter · #12 ·
I tried one just like this exactly , i just plugged the new abs without removing the old one from its place , started the car , lighta went off for 1-2 seconds and they came back again. Do i need to program something or just erase the codes when trying new abs module? Thanks for your help
2001 SLK230
Mine was plug and play. My issue was that the ABS pump would not shut off when I turned off the engine. My Indie friend diagnosed that it was a defective ABS Module. I removed the old module, installed the new one and problem solved. No programming required.
2001 SLK230
Discussion Starter · #14 ·
Now that i remember , the other abs i tried was from a clk w208 abs with matching number but Q05 not Q06 , that might have been the problem for not working like.it should
2001 SLK230
I still have my old module attached to the pump I purchased that's stored away. I'll have to go check it today to see if it's Q05 or Q06.
2001 SLK230
Here is a photo of the original ABS Module that I removed, shows Q 05.
Font Gas Number Auto part Electric blue
Here is a photo of the ABS Module that I purchased and installed, shows Q 06.
Font Motor vehicle Gas Electronic device Vehicle
Here is a photo of the original ABS Pump that is still on the car.
Liquid Fluid Automotive tire Drink Bumper
2001 SLK230
Discussion Starter · #18 ·
So it doesnr really matter if its Q05 or 6 , i will try another one tomorrow but im hopeless , dont really know what to do, do u have any ideas what can cause this , brake light switch works , the codes erased itself like 3 times for like 20m , is this an abs sensor problem?
Founding Member 2006
From @Sneaky Pete :
Did some searching on Dutch and German MB-forums.
According to the guys who really know their stuff the "Q" stands for "Quality".
Meaning that Q06 designates a slightly improved version of the same partnr with Q05-Q01. As I understand it as lonf as the partnr is the same they all will work just that the ones with the higher Q nr are of a slightly better build quality then the ones with a lower.
2001 SLK230
Discussion Starter · #20 ·
From @Sneaky Pete :
That means there is no problem with that , should i change abs sensors again or what
1 - 20 of 25 Posts
