Hi to all,
Just about to change brake pads on the above. I did take the old pads out just to check the right fitting before I ordered new ones they Are fine. I did put the old pads back in and had to push the piston back using just a bit of pressure and a screwdriver. My question is , when I do this should I be winding the piston back in. Also is it necessary to remove the caliper to change the pads it just a single pin holding them in
Marauder
Registered 2009 SLK200
Hi to all,
Marauder
Simple procedure to do no special tools req
And the piston just slowly pushes back
Just make sure inside is cleared of any debris and some copper grease is used on pads edges etc and pins .
SLK 200 brakes
Hi
Thanks for replies , job done
Fairly straightforward. Just pushed the Pistons back slowly as there were no notches in the piston.
I take it the front is just as simple ?
Thanks again
Marauder
