1 - 10 of 10 Posts
Hi! I was wondering if any of you could help, see, today I parked my 2006 SLK200 at the gym and when I went back to it I noticed something different about the passenger's side mirror. It seems someone hit it or something similar, so it is displaced now, its a bit too extended and also the closing mechanism doesn't work at all. I managed to strip it down (following some awesome guides I found here) up to a triangle and a pin (picture attached) that I'm too afraid to take out in case I break it. All this got me nowhere and I have no idea how to fix this. Any way you guys know how to fix it? Will I have to buy a whole new mirror? Thanks in advance!
*DAS/STAR Premium Member
2005 SLK55 AMG
Morning and welcome
Please fill in your details on your profile as it helps no end - the Master Sarge will swing by shortly will a list of useful links and stuff
Can't really see whats wrong from the one small photo - you're going to have to remove the mirror from the car and strip it to find the damage, but given that these are cast it sounds like either a part of the frame has been broken, or the folding mechanism has been smashed - sounds like someones hit it and left without letting you know
Mirrors are easy to replace (3 torx screws and a couple of electrical plugs), but not the cheapest - you can buy them on the usual auction sites (main dealer prices for new ones tend to be a bit scary), and it doesn't matter if the one you're buying is the wrong colour as you can strip out the frame and use your own covers etc.....
Facelifted ones tend to be a bit more difficult to find than the earlier ones
Reactions: etyu and 55russamg
Founding Member 2006
Here I is!
Delvecchio,
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
2004 SLK200K
As Sean suggests, it sounds like they make have broken something in your folding mechanism and as it looks like you have electrically folding mirrors, they're not the cheapest to replace...
2005 SLK55 AMG
And they all fit on each car - ie, you can put facelift on a pre-facelift and visa versa
If mirrors have extra functions to those originally fitted then coding (and other hardware) may be needed to activate / use them
Reactions: PitchRate
go careful when you remove that pin,that is one strong spring underneath!
clamp it up in a vice,then remove the pin.
I took mine apart for the same problem,took me a while to work out where the mirror rest in folded position and how far out it moves.
Mine had just jumped a cog as it were.
A lot of grief and I didn't think it would all go back together,but works perfectly now.
Martin
Discussion Starter · #9 ·
Thanks guys!! I'm awfulky sorry about the profile, I'll complete ASAP! Also, I'm going to try and do what Martin did, disassemble it past that triangle clasped onto the pin. Last time I didn't really know how to undo the triangle and got a bit scared when I saw the spring you speak of.
2005 SLK55 AMG
Here you go - here's a pic of one of mine stripped down
Reactions: etyu
1 - 10 of 10 Posts
