I found the clear or smoked side marker lens at an outfit in California
Uniquestyleracings.com I got the smoked lens instead of the clear. I was going to replace my w5w bulbs with amber w5w canbus led's anyway. Lens part looks good. The back part (where the bulb goes in) is thin plastic. As this should not be a problem as this side would be in the car, the led's would emit low heat and the led's would last a long while. The back part of the lens (closest to the door) is brightest (as that is where the bulb is) and fades forward. I like the way it looks.
Will do by this weekend when the weather breaks. Today I purchased a Colgan sportbra for my hood. Helps protect against rocks and chips. I won't arrive until sometime in the middle of May.
