Sorting out an issue with a no shift out of 1rst problem. Any expert help would be appreciated!
Faults are ... no communication with ECU, left rear speed sensor implausible...same for the right one. also speed sensor a problem, also output speed sensor circuit problem, all 4 speed sensors ohm out the same where they hook to the abs unit and fronts are working when looking at live data stream. Manual insist there is a traction control module at right rear of engine compartment...there is not one there. Someone said it is built in to the abs unit. It also says that the steering angle sensor is not reading. So this thing will not drive without abs in tip top shape? ..... tired
ps...tried another shifter, tried another ecm, tried another abs unit, have traced and tested ALL connections.
Bad job testing fuses. Blown fuse was problem. Still have dead can bus. Cannot find bus terminal block.
