1 - 12 of 12 Posts
Registered 2009 SLK200
I have just done the C-service on my SLK r171 2009 (after facelift)
It was according to my local merc dealer (after some discussion)
Oli and filter,
Air filter,
and spark plugs.
I am now looking to prepare for later services and have used a very clever app to translate the text in my German manual.
On the side I scanned there must be a mistake. It says air filter chane after 4 years but also after 80000 and 100000 km.
The rest of the service I think I understand.
According to my (German) manual the service is like this
I have ignored som checks that I feel I do continiously.
25000km
Check Winscreen wipers and stuff
Check brakes (fluid pads and disks)
50000
Check Power steering oil level
Every service (every year)
Oil and oil filter (15000km)
Every second service
Brakefluid change.
Every 3 years
Cooling fluid change
Every 4 years 80000km
Air filter
Spark plugs
Thanks for the help so far!
Jörgen
I have read that but when You have all the different systems in the same thread it is a very big amount of info.
I just did the C-service and the next (according to the indicator) is A.
I think I will go after the years, I guess we will drive so little that the mileage wont come in to play.
it usually goes
A B A C A B
which equates to time/mileage with 'major' service at B & C like brake fluid, trans service etc
it usually goes
A B A C A B
Yes, just as on the Smart Roadsters I had.
I am more interested in what needs to be serviced. How often do I change, for example, the fuel filter?
Jörgen
fuel filter page 78
Service at 150,000 miles or 15 years
miles...not km...you can convert :D
Premium Member 2012 SLK55 AMG
Although this is from my service booklet it covers the major service items.
From my Service Booklet - Additional Maintenance Work SLK 55
At every Service
Engine Oil changed and Filter replaced
Every 2 Years
Brake Fluid renewed.
ONCE after 1850miles
Rear Axle oil change (Only for those cars with rear axle differential lock which comes with options P30 & Option 471)
Every 31,000 miles or 3 years whichever comes first
Air Filter Element replaced.
Rear Axle oil change (Only for those cars with rear axle differential lock which comes with options P30 & Option 471).
Every 46,500 miles or 4 years whichever comes first
Spark Plugs Replaced
Every 77,500 miles or 5 years whichever comes first.
Automatic Transmission Oil changed and Filter replaced.
Every 155,000 miles or 15 years whichever comes first.
Coolant renewed.
Fuel Filter replaced
:D of course different engines...poster has m271.. have different time frames
1 - 12 of 12 Posts
