Secondary air pump relay location SLK320
5715 Views 6 Replies 6 Participants Last post by  Avel Du
Hi evening all,
Has anyone got a photo showing the location of the Sec Air pump relay on a UK model SLK320.
Regards Stuart.
Can any one help here plzz???
This thread is a year old
do you have the same or another issue?
update your profile, model n year n location as below and in your message I sent you
Post an introduction
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members...pdate-your-profile-post-intro-smartphone.html
See less See more
This is the K40 relay module with sec air pump relay incorporated.
See less See more
Reactions: 1
Ooops, I didn;t notice you were looking for the relay.
Just in case you're chasing a secondary air problem, I can add that my fault was caused by a K40 relay board problem.
Reactions: 1
We can better help if we know a little more.
An introduction would be welcomed.
What car?
What year?
Where?
See reply above for how to solve these questions.
Thanks.
Myk
See less See more
