1 - 16 of 16 Posts
can anyone tell me where the seat adjuster relay is situated? adjustment has been intermittent for a while,but now has stopped working altogether:crying:
Relay
Bearing in mind I am in the UK and right hand drive mine was to the upper right of the steering column behind the dash. Took mine out and re soldered all connections on the PCB now it works fine.
Plenty of info on doing this.
Regards
Neil.
Oh your in Yorkshire LOL.
Also the relay is the larger black one.
Regards
Neil.
so,access from behind the instrument cluster then?
Having the whole wiring harness, along with the seats, removed from one R170, and put into another, I do not recall having any relay.
The whole thing was one harness, that on one end has 2 cables, connecting into the fuse box, another 2, which went to ground, connected to the wall of the car, and two ends at each side which plugged into the seats.
Below the seats is where all the magic happens.
This is how mine was, maybe yours is different.
Pull the a/c and head light unit out located to the left of the steering wheel. I have 02 320slk WHICH THE SEATS stopped working. I ordered the relay from Rock Auto, opened side fuse panel cover, removed the screws holding the fuse block in place, pulled the a/c head light unit forward and removed. Once the head light switch unit is removed you can see the seat relay (black one inch square to the right & rear of the fuse block. Had a little trouble getting the relay out (just wiggle and pull) Replaced the relay and tested the seats...They work! reassembled the parts and it took about 1-1/ hour.
fyi this thread is 3 years old
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. Click this: http://www.slkworld.com/new-members-introduce-yourself-here/
If you wish to become PM (Private Message) capable or to ‘edit’, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members as we welcomed you to obtain your needed posts to PM/edit. You can always pm a moderator.
Want to ‘like’ or thank’ someone’s comments? Use the ‘like’ button to the right or the ‘Thanks’ button, bottom right of any post you like. This saves you having to comment or use the 'quote' button so we know who you are asking or replying to or referencing.
Administrator/Founding Member
Still relevant tho Boss :grin:
As are these that are in the DIY Section:
JaysonM's excellent Intermittent seat adjustment problem. Seat relay fix.
And for those of us that have the steering wheel on the correct side of the car - Seat relay location on RHD right hand drive SLK R170
:nerd:
Still relevant use...but...
if he is not aware of
posting in an old thread...the one he is addressing might no longer be an active member
so like talking to my wife...it lands on deaf ears...but i thank you as usual :D
https://www.slkworld.com/new-members-introduce-yourself-here/233026-posting-old-thread-how-fix.html
1 - 16 of 16 Posts
