1 - 9 of 9 Posts
I need a safe way to remove paint from plastic and vinyl. I'm redoing an interior on my SLK.
TIA,
Randy
I've always wiped automotive plastic and vinyl down with lacquer thinner, on a soft cloth. Good and damp, but not dripping. It should remove old paint and grim - while at the same time preparing the surface of the plastic/vinyl to provide a good base for the new die or paint.
FWIW,
Carl B.
I suppose that if you left a piece of plastic in a bucket of Lacquer thinner - it would dissolve it. Or if you left a dripping wet rag soaked in lacquer thinner on the plastic for a period of time it would soften it.
But wiping automotive plastics and vinyl down with a damp cloth to clean the surface and remove old paint with lacquer thinner - won't hurt a thing. At least is hasn't over the past 40 years I that use it, during the restoration of dozens of cars.
Using alcohol won't leave the plastic/vinyl with as good a base to apply dye or paint to. If your going to re-dye or paint the plastic/vinyl - use Paint Thinner to clean it {aka lacquer thinner}.
If you use Alcohol - be sure to clean the plastic/vinyl after with clean water, then dry completely.. any residue left will let your new paint peel off like a baked chicken skin.
Carl B.
Isopropyl alcohol worked for me in about 90% of the areas I was working on. Brake fluid took care of the rest.
Remember ventilation, gloves and goggles whatever the chemical you decide to work with.
Motodr,
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already.
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Post your vin in the Vehicle Datacard Request section to get a datacard (options on your car). http://www.slkworld.com/vehicle-data-card/
1 - 9 of 9 Posts
