1 - 8 of 8 Posts
In the underside of the doors of my SLK are 4 rubber caps.
When I remove these caps I see some kind of adjusting / set screws.
What can be adjusted with these screws?
Check out the parts https://slk-links.neocities.org/EPCLINKS.HTM
With luck you will find an exploded view that gains insight.
Also, check out your handbook. Might find nothing but....
Most likely the screws are for adjusting the alignment and/or height of the windows.
On exploded views it is not clear to me which screw has which result.
The windows on my car seems well aligned, but I hear wind noise and on the forward top corner I see waterdrops in heavy rain.
Anyone can help?
Anyone can help?
As others said, if it leaks at the seals first try Gummipflege (cheapest) or the MB stuff (expensive) or Krytox GPL105 (very expensive).
Before you start turning screws to adjust the front windows read these WIS docs first. https://drive.google.com/open?id=1Ud-zWhsVwtcJ-GEgjc1cP4ypSEj45MAd
You might do more harm than good.
If after that you still want to go ahead, I say "hats off...."
Anyone can help?
As said before, lube the rubber first.
You can also take a look at this video
https://youtu.be/2Xu-UuDv9sA
It describes checking and adjusting the roof seal joints.
1 - 8 of 8 Posts
