Hi all
So the other day I was driving home and some guy behind was being....... "one of those".... so at the appropriate time, I floored it and I noticed after releasing the pedal the RPMs dropped from the sort of 7-9k whatever it is down to 4k and remained there even though I was now driving normally. It hasn't done it since... but has made me wonder why that occured and I haven't gone to those kind of speeds since as bit concerned what that was... it hasn't done that before.
Any thoughts?
Maybe my English is not good enough for some subtleties... I read all two pages and I'm still not clear about what happened.
Briefing those two pages:
So you used the kick-down, which makes the car going to the shortest gear (certainly not anywhere near the 7-9k range since your engine doesn't get that up, but understood: near the red line) and kept accelerating. Once the situation cleared off,
you released the gas pedal. The gearbox upshifted like two~three gears (depending on your current speed) so it reached about 4000RPMs and then it stabilished there even given
you completely left the gas pedal alone and
it stayed that way for about a minute.
So the first thing I want clarified is: in your first message you said
"remained there (at about 4k RPM) even though I was now driving normally", but then you said afterwards
"all I was doing was coasting along, no pedals pressed". That makes a huge difference, so what was it? Were you driving "normally" as in "not spirited" or did you take your foot totally out of the gas pedal?
You later on even said
"the engine was truly reving at that 4k speed it wasn't just the gauge. But, it was like the car was in neutral as the car wasn't actualy trying to "drive" it was just coasting"". I don't get what this exactly means either.
If your engine really was in neutral (just let's imagine for a moment it used a manual gearbox), of course the engine could be at whatever RPMs as you pressed the gas pedal (or else, in case of gas pedal failure, at whatever the electronics "thought" you were pressing the gas pedal), but the speed would be slowly going down (as no engine would be pushing the wheels but nothing would be braking it either). So, was the speed in that situation slowly going down, as if truly in neutral, somehow quickly going down, as when the gas pedal is not pressed and the car is slowering down due to engine brake, or was it sustaining its current speed as if you were just gently pressing the gas pedal just for the speed to be maintained?
Now, while I wait for your answers to my questions above, I'll advance what I think it's the most plausible explanation (unless your answers point somewhere else).
Let's forget for a moment about the engine's RPMs, and let's focus only on the gas pedal: you quick-downed, went accelerating for a while and then you released the gas pedal, also for a while, till you reached your desired cruising speed again, then you gently pressed gas pedal as to maintain your current speed. Like when overtaking on, say, a 100kph-limited road: quick down for overtaking, let's say the car goes up to 140kph, and once the overtaking is finished I just let the car go, so it speeds down, and once back at 100kph, I press the gas pedal just enough to sustain those 100kph. Is that it?
If the case was the one I painted above, then I'd say everything was normal with the only minor caveat that, yes, sorry, there's a bit of "operator error" as you said, going there. Not really operator error but just that your "full minute" wasn't that much but just about 15 seconds to half minute and it just seemed to you much longer. Otherwise, depending on the exact answers to my questions above, I'd look towards gas pedal malfunction or gearbox' conductor plate failure early symptoms.
PS: now that I think of it, was the cruise control activated?
