Hi all,
Hoping someone on here might know the answer to my problem. Due to a blocked drain channel the passenger side of the car got flooded with rain water.
Spent the day ripping out the interior and the passenger side carpet so I can finally start to dry everything out.
I reconnected the window switches, centre console switches and the vario roof switch and went to close the roof and nothing happened. Window and roof switch are totally dead. Yet worked perfectly an hour earlier. Air bag light on the window switch panel is also lit.
The roof is down but not properly stowed - keys were removed from the ignition before the roof could fully retract (not my doing!) so it folded up but the boot is open.
Just wondering if there is anything I have missed? Is there some reset procedure required after switches etc have been disconnected? Cant be anything more serious as everything was working fine an hour earlier.
Been doing some searches but can't seem to find anything that points to a solution for my problem. Hopefully someone else on here might have the knowledge!
James
James
