Its been a wonderful 2 years of ownership of my SLK 200 R170.Now after being outdoors in a brutal
winter the roof refuses to open.Does anyone know how I can go about fixing this problem?
Diagnostics etc.Or is it a trip to a garage.Such a nice drive!!!
A little more info need as there can be many reasons for a failed roof.
ROOF R170:
SDS scan is best starting point.
If you do not have access to SDS, some fixes are quite simple.
For the roof to work it has to pass several safety features.
Including, but not limited to:
Wheel speed sensor.
The blind in the boot has to be in place.
The door windows must lower.
The rear quarter windows must lower.
The roof catches in above the windscreen must unlatch.
The boot must open.
The battery must be in top condition (best having the engine running when playing).
The hydraulic fluid must be at the correct level.
Before agreeing to work, try working through our diys if you cannot get the SDS scan.
(MB Indy will charge between £40- 100 for this).
Nice document.
www.slkworld.com
Is the Vario Roof on your SLK stuck or malfunctioning? In this video we'll show you the procedure for manually closing the retractable hard top on your 1996-2004 SLK, so that you can get your car weatherproofed and buy yourself some time before diagnosing and fixing it. jb edit...edited to...
www.slkworld.com
Nice document. says r230 which is sl but similar to r170
www.slkworld.com
www.slkworld.com
Courtesy of Leapyfish Click on attached PDF edit: https://youtu.be/uXKSfLEPWgE
www.slkworld.com
http://www.benzworld.org/forums/r170-slk-class/1416185-vario-roof-button-blinking-need-help.html
www.slkworld.com
There may also be some videos:
https://www.youtube.com/playlist?list=PL7P_LHAJFk_tvwerkvQavsyqsacOm0jTR
www.slkworld.com
DIY Mercedes Benz SLK230 Maintenance https://www.youtube.com/playlist?list=PL4kCxFVdSSQRal7cSMpadDMvOnXuOqoGQ
www.slkworld.com
https://www.youtube.com/playlist?list=PLsoW__ztUKTPknPvDU9dOhdmdMOuH-OjR
www.slkworld.com
Some fixes are very easy, others are more technical.
It is well worth working through those lists before committing to work.
