1 - 15 of 15 Posts
Registered 1999 SLK230
Today I went to lower my roof. The rear cover would not come vertical enough to let the roof go over it. I noticed that the pictured part on the left corner cover was broken. It pulls the corner cover clear of the headrest. I know that the corner cover got caught on the head rest when I was investigating the problem, so I am not sure if the failure of the corner cover to be pulled out of the way was a cause, or a result, of the pictured part breaking.
First, what I need to know, is the pictured part the part #24 in the diagram (strap). Once I replace that part, I can further investigate the roof opening failure.
Thanks in advance.
you want to know if that is called the strap?
called tensioning rope ???????
140 in pic
used to be called cable, now tensioning rope
140 A 170 690 03 17 CABLE
Replaced by: A 170 690 04 17
140 A 170 690 04 17 TENSIONING ROPE 002
Thanks, but no luck at any of those places using the name or part(s) number. I had tried those before posting. I cannot even find the part on the diagrams.
Dealer?
Leave the A off and try again :D
Thanks again!
Still no luck. I have tried:
140 170 690 04 17
140 A 170 690 04 17
170 690 04 17
TENSIONING ROPE
on all 3 sites. Nothing even close.
Thanks again!
140 170 690 04 17
140 A 170 690 04 17
170 690 04 17
TENSIONING ROPE
see my posts 9 & 10?
1706900417 was used take out the spaces :D
Discussion Starter #13
Finally found the part number with some help by jbanks15. The part diagram I found was a little different and had the name hinge in it.
I went to the dealer and found part 140 listed as tensioning cable. It was listed about $25 more at the dealer than the 'hinge' part. I figured what the heck and paid the dealer $75. I know I will get the right part now and I did not know what shipping was going to be anyway.
After the part goes on, I will see if helps my roof function.
Thanks for all the help.
Registered 2000 SLK230
Been looking for the same part and also found other part images that don't look right.
There is a YouTube video on installing the bugger. Hard to believe the price for such a small part!
How did it the installation go?
Bryan
2000 SLK230
Discussion Starter #15
I succumbed to buying at the dealer.
Watching the video was a great help. A little fussy, but certainly doable.
1 - 15 of 15 Posts
